Happens almost if not every time. Under the hood it will start clicking either on idle or when moving very slowly as in 1 - 5 mph, during the clicking the engine will miss and sometimes shake the car, sometimes louder than other times. It has not yet died but i would expect it to. No other symptoms. I wanted to know is it possible that you are 100% sure what the problem can be out of the 3 possible problems the mechanic gave me. He doesn't know which one. At first it was just clicking for the longest time not every time low tone and then a few days ago lots more clicking louder, shake, miss.
1) Coils - i have 1 original coil and 1 new coil in ; would putting the other coil in fix it
2) The part that the coils attach to i don't recall the name
3) compression from engine
May or may not be related: Engine light is on. Each time it will say EGR in one form or another doesn't stay the same. Every single solution for this code has been done. Random and never stays on, no set time when it goes off either however it never turns on until i start going for at least a minute or two.
I understand this is a repeat question but there are new developments and it's none of the solutions you mentioned before for certain. Maybe with this information you can determine the source.
Thanks for your time.
Jun 11, 2015 at 3:03 PM
