1993 Saturn SL1 ENGINE STALLS WHEN APPLYING THE BRAKE
169,000 MILES • 4 CYL • FWD • AUTOMATIC
PROBLEM-SOLVER
THE ENGINE STALLS WHEN I APPLY THE BRAKE. I HAVE CHECKED THE BOOSTER AND THE VACCUM LINES.
Jul 5, 2010 at 6:55 AM
SATURNTECH9
  • 30,869 POSTS
Is the only time it stalls is when you apply the brake?Also have you checked the alternator and battery?Have you checked the car for codes?
Jul 5, 2010 at 7:00 AM
PROBLEM-SOLVER
Yes, the only time it stalls is when i apply the brake. The battery and alternator is fine. The car starts easily and idles fine.
Jul 5, 2010 at 7:14 AM
SATURNTECH9
  • 30,869 POSTS
How did you check the vacuum booster?Did you use a vacuum pump?
Jul 6, 2010 at 4:25 PM
