It starts but when you touch the gas pedal it shuts off. touch the gas pedal if it does run it runs badly. when you started up and then runs perfect it will not happen. came home went to church came home shut it off. We have started back up and it has been at Fowler's tracks because it is running some badly I do not know what happened to it.
Also, I put a new timing chain in. I have put oxygen sensors, camshaft sensors has a start pop through the exhaust. I cut the catalytic converters off it still does not have enough power to pull itself out of the tracks like I said hit run perfect until I shut it off.
Apr 4, 2018 at 8:04 PM
