Water sound in dashboard when car start idling
106,650 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JAMES SHAND
  • 13 POSTS
Hi guys,
So I hear this sound of water from my dashboard after i start up my car. Duration its about +- 4 minutes. Upon investigation I understand it's a airlock in the heater core. So I just want to know did anyone experience this already? Is it something to loose sleep over? Because coolant level it's normal.
Aug 11, 2020 at 8:56 AM
You are correct, you have a air pocket in the heater core. This is normally caused by a small leak somewhere that is allowing air into the system. It could be the heater core or it could be somewhere else. Best way to determine this is to pressure test the system and see if it can hold pressure for a while. I suspect you will not hold pressure for long and if not then we need to find where it is leaking.
https://www.2carpros.com/articles/radiator-pressure-test
Let us know what you find. Thanks
Aug 11, 2020 at 11:04 AM
JAMES SHAND
  • 13 POSTS
Thank you, I will speak to mechanic. They need to fix it because last time he told me also about it meaning he is aware of this problem.
Aug 11, 2020 at 7:36 PM
JAMES SHAND
  • 13 POSTS
So what I notice also is that my car gets like hot inside when I drive even when the heater is not on. So i guess it's because of this problem? Right
Aug 11, 2020 at 10:02 PM
Yeah. I suspect the heater core is leaking and the air is blowing over the hot coolant. If you get the hot air again, try to smell the vents and see if they are a little sweet. That would be the coolant.
I think you are on the right path. Let me know what happens with this one. Thanks
Aug 12, 2020 at 10:59 AM
JAMES SHAND
  • 13 POSTS
Okay, great Kasekenny. I will definitely do that.
Aug 12, 2020 at 1:55 PM
Sounds great. Keep us posted with what turns out on this one. Thanks for the update and using 2CarPros.
Aug 13, 2020 at 11:56 AM
JAMES SHAND
  • 13 POSTS
So I moved to my old mechanic to a new one. Seems like my problem is not resolved, she find that the cooling system it has definitely got a lot of pressure so much so that the pipes swell terribly. She will do the pressure test shortly and will let me know.
Anything you guys got on this or what will be the course led to this problem?
Sep 2, 2020 at 9:47 PM
JAMES SHAND
  • 13 POSTS
So she just told me now the head gasket went. She will let me know about any further damages ones the cylinder head being removed.
Sep 2, 2020 at 10:50 PM
Sorry for the delay but clearly you found it. Any time we have excess pressure in the cooling system, it is most always a head gasket.
Sorry, that is not good news but at least you got it figured out. Thanks for the update. Let us know if you have more questions. Thanks
Sep 3, 2020 at 10:52 AM
