Sunday, October 13th, 2013 AT 8:50 AM
The OEM fan clutch wrench set is too thick to fit in between the pulley and the water pump. I do not know where to buy a thinner a wrench. The final bolt (top right) on the water pump is blocked by the tensioner unit/compressor/ power steering pumps (they are all bolted together). What do I do there? In the manual its says that I 'may' have to the remove the all those extra parts, it seems like that is more than I should be doing. What am I supposed to do?
