Water leaking
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAKOTA420
Leaking water from what I assume is the water pump I put coolant in as soon as I start it it starts leaking out
Nov 19, 2018 at 11:20 PM
  • 110,248 POSTS
First, take a look through this link. It discusses water pump issues and how to check one.
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
If the pump is bad, here are general directions for replacement.
https://www.2carpros.com/articles/water-pump-replacement
If you find it is not the water pump, here is a link that shows how to find and repair a coolant leak. Since the coolant leaks out so quickly, I do not see the need for a pressure test.
https://www.2carpros.com/articles/car-is-leaking-coolant
___________________________________
Let me know if that helps. If you find the pump does need replaced, let me know if this is for a 3.0L or 4.0L V6 engine so I can provide specific directions.
In addition, if you have to drain the coolant to replace the pump, consider replacing old hoses, the thermostat, and it is a good time to flush the system. It is easier to do it at this point because if something fails, you have to drain the coolant all over again.
https://www.2carpros.com/articles/replace-radiator-hoses
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Nov 20, 2018 at 10:36 AM
