1995 Ford Aerostar overheating with new water pump & go
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
PB33141
On my temp. guage (NORMAL) It never used to go over the O or R on temperature.
My water pump started leaking so while I waited for a pay check I used 3 containers of a gold (glittery) looking (stop leak) over a one week period.
We finally changed the pump and it still went to extremely hot after driving for 30 minutes.
I had the thermostat checked & the mechanic said it was ok and sent me to a radiator specialist who told me to go home and flush the radiator.
I removed the lower hose and flushed it 3 times.
It still over heats although it got a little better.
The only other symptoms the Aerostar is having is an occasional puff of white smoke at start ( maybe 3 out of 10 starts) and thats only at the start of the day, after the first start it gets no smoke while engine is warm. and now I occasionally hear a putting sound at the engine (only sometimes) while in drive.
Please help I can only drive 30 minutes at a time.
Paul 305-609-3945 or 305-891-1820
Thanks, My mechanic can'tfigure it out.
Aug 6, 2009 at 5:57 PM
  • 110,248 POSTS
If you are seeing puffs of white smoke, my guess is you have a blown head gasket. Run a compression test on the engine to determine if there is a cylender with low compression.
Let me know what you find. Also, did you flush the engine block?
Sep 11, 2009 at 1:09 AM
