I am leaking water from under the dashboard when air conditioner is running.
Jul 16, 2017 at 6:58 AM
SATURNTECH9
✓Experienced Mechanic
Sounds like your A/C drain is clogged. the A/C drain is usually on the center of the firewall it will be a hole or a rubber tube coming off of it. You can clear it with a metal coat hanger if it is just the hole. If it is a tube you should be able to clear it by massaging the tube to help push the blockage out.
