Vibrate in gas pedal and floor
77,400 MILES
LEVANE RAPE
  • 6 POSTS
I have put tires on and u joints in center bearing in the drive shift trans mount and still have a vibrate in the gas pedal and floor board what can be the trouble it is on a 2007 Toyota Tacoma prerunner sr5 v6
Nov 16, 2013 at 8:04 AM
  • 110,248 POSTS
If you feel the vibration in the floor, chances are the problem is in the rear. Did you check for a bent rim? If you rotate the new tires, does the problem change? Is there any excessive play in the rear axles? Were all U-joints replaced?
Nov 16, 2013 at 8:20 AM
LEVANE RAPE
  • 6 POSTS
Rotating the new tires done not change it and yes I did change all of the u joints and the center bearing
Nov 16, 2013 at 8:29 AM
LEVANE RAPE
  • 6 POSTS
Did you get my last reply levane rape
Nov 16, 2013 at 8:48 AM
CJ MEDEVAC
  • 11,000 POSTS
HOW'S THE OLE MOTOR AND TRANNY MOUNTS LOOKING?
ARE YOU SURE IT'S NOT ENGINE RELATED, SUCH AS A CYLINDER MISFIRE?...IS THE CHECK ENGINE LIGHT ON?
THE MEDIC
Nov 16, 2013 at 9:49 AM
LEVANE RAPE
  • 6 POSTS
No misfire runs great no check engine light is on can it be in the trans sometime it shift fast but it may not be in it, we run a body shop and can't figger it out hope you can help thanks so for helping me I don't won't to sell it because of this I like the truck
Nov 16, 2013 at 10:00 AM
LEVANE RAPE
  • 6 POSTS
I put a trans mount on it today got it from Toyota still the same thing
Nov 16, 2013 at 10:18 AM
LEVANE RAPE
  • 6 POSTS
Nov 16, 2013 at 7:27 PM
  • 110,248 POSTS
If the u joints are new, the tires are new and there are no bent rims, the mounts (trans and engine mounts) are good, and the driveshaft isn't bent, then my guess is there is a problem in the differential itself. Have you checked for excessive play in the differential where the rear of the driveshaft attaches? Any excessive play in and out of the wheels? Any noise coming from the differential area like a growing noise?
Nov 17, 2013 at 7:01 AM
