Water leak after replacing the water pump and thermostat
1,000,000 MILES
LACY FERRELL
Last week the water pump and the thermostat were replaced and now there is leaking. I can see the leak, but I cannot find the precise location of it. is there any way that I could?
Nov 5, 2021 at 1:30 PM
  • 110,248 POSTS
When you see the leak, the best thing to do is this: Get a pressure tester (most parts stores will lend you one) and slowly pressurize the system when it's cold. Once a specific pressure is reached, the leak will start. At that point, see if you can identify the source.
By doing it this way, you can take your time and not get burnt. Here is a link explaining how it's done:
https://www.2carpros.com/articles/radiator-pressure-test
Also, if possible, take a few pics of where the leak is seen. Hopefully, I will have a few ideas as to where it could be coming from.
Nov 5, 2021 at 2:42 PM
