2004 Chrysler Pacifica coolant leak
130,000 MILES • 6 CYL • FWD • AUTOMATIC
CRIVAS
I have a 2004 chrysler pacifica and it recently started leaking coolant. we changed the hose that had a hole in it and it still leaks. there is no coolant mixed with the oil but it leaks by the passenger side tire. it was a slow leak but now leaks pretty bad.
Jun 23, 2010 at 3:48 AM
DOCFIXIT
  • 18,828 POSTS
Might be water pump on front engine ie. pass side
Jun 23, 2010 at 4:41 AM
CAR4424
  • 36 POSTS
I agree or the metal flange the lower radiator hose clamps to, there is a gasket behind it
Jul 17, 2017 at 1:34 AM
CHRISTIE466
I have coolant leaking some where other than the water pump, some where further back on the engine. when I park there is a puddle. When I fill it runs out slowly. Seems to be coming down to oil pan. You have heater hoses that go near the middle of the engine on the drivers side and could leak down to the pan Help?
Jul 18, 2017 at 3:04 AM (Merged)
  • 55,616 POSTS
Yes that is a common leak on those cars, here is a guide that will help you find out where the coolant is leaking from.
https://www.2carpros.com/articles/car-is-leaking-coolant
and
https://youtu.be/W8kra65m15c
Cheers, Ken
