Water circulation, water keeps disappearing from recovery tanks?
12,163 MILES • 1.6L • 4 CYL • AUTOMATIC
CARYAH GIJA
The car has no leaks, water not mixing with oil, but I will keep on adding water in few kilometers of driving.
Jun 9, 2024 at 4:27 PM
STEVE W.
  • 15,406 POSTS
There are only a few places that coolant can go in an engine. You don't see an external leak or coolant in the oil, which suggests that it is likely a bad head gasket and the coolant is being used that way. This shows a few tests that can be done to determine if that is the case:
The pressure test and chemical test can usually be found as loaner tools at a parts store. I would suggest doing them and then you can decide what to do from there.
Jun 9, 2024 at 10:20 PM
