I was driving on the highway and noticed that my AC started blowing hot air. I looked at the gauges and noticed that the engine was almost to the peak of the gauge runing hot. I immediatly turned the heat on and the temp came down to safe levels. So I have noticed that the temp goes up with the AC is on or if the car is in idle. If the car sits for a while and cools down the AC will work untill the engine runs hot. This happened while I was out of town on a sunday so I had to drive home with this problem. Thank goodness having the heat on and not going to fast kept the temp down to safe levels. What could this be?
Feb 22, 2010 at 8:01 AM
