Washer fluid pump/motor
100,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
POLARBEARMAPLE13
When I try to use my washer fluid, there is no longer the "wrrrrrr" noise of it trying to pump fluid. Does this mean a motor down there is broken? I purchased a new washer fluid pump, but will this fix the problem if it is no longer making any noise when I try to use it?
Jan 14, 2019 at 11:48 PM
DOCFIXIT
  • 18,828 POSTS
Hi this link may help. Testing for voltage at motor when operating will tell if motor or problem elsewhere. Have you checked windshield wiper fuse?
https://www.2carpros.com/articles/how-to-replace-a-windshield-washer-pump
Jan 15, 2019 at 4:21 AM
