Take the front passenger side wheel and splash shield, and you will see the canister/resovour in there, there's two bolts you need to unscrew, but before you do that, you will need to drain the fluid first, since you will have to take the hose off.
SPONSORED LINKS
Friday, September 14th, 2007 AT 12:05 AM
