2005 Volvo XC90 Tire Noise
TDONGINAO
I have a XC90 - 2005 and am noticing some noise when I am driving. I think it is coming from the tires. They are original to the vehicle with 41,000 miles. You only hear it when you get above 45-50 mph. What could this be?
Apr 8, 2007 at 1:24 PM
2CARPRO JACK
  • 11,533 POSTS
Under or over inflation could cause this.How is the wear pattern on the tires? A feathering or uneven wear wiil make noise.at 45k they should probably be due to be replaced soon.
Oct 16, 2007 at 3:52 AM
Suggested Repair
Check tire inflation and look for feathering or uneven wear. Original tires at about 41,000 miles are likely due for replacement soon.
Conversation Summary
The owner of a 2005 Volvo XC90 hears noise above 45-50 mph and suspects the original tires, which have 41,000 miles. The expert says under- or over-inflation, feathering, or uneven wear can cause the noise and that the tires are probably due for replacement.
