I recently recharged my A/C system after leak test showed OK. Within two days system was not blowing cold again. Compressor was cycling on and off. Is there a good diagram somewhere showing the entire system and also where are the vulnerable connection points to check. I can find no oil on any of the lines that are visable. I will use a dye next but am wondering where the real trouble spots are in my particular system. Do you have a good method for determining the origin of the leak. Thanks Dan m
Jun 28, 2010 at 3:46 PM
