1998 Volvo S70 power windows/doors
1998 VOLVO S70
13,600 MILES • 6 CYL • FWD • AUTOMATIC
LKS614
My driver's window is down and won't come up, driver' door locks w/key fob but won't open; passenger front right door button closes w/key fob but the doos remains unlocked; rear right passenger window will go down using driver's switch but not close, have to use the passeners button, also antenna does not go all the way down. Are all the window/door motors not working and what would the approximate cost be to fix all of this? Thank you.
Jun 8, 2008 at 10:43 AM
2CARPRO JACK
  • 11,533 POSTS
Start by replacing the main switch (drivers). all the windows go through it , replacing it may make some of the other window problems go away. As far as the door locks, need to test the actuators to be sure they are getting signal to unlock, usually if they work one way but not the other it is the actuator , but testing is req'd to be sure. The antenae, may have a slight bend in it that is keeping it from telescoping into itself, or it may need a little lube, try a small shot of WD-40 before replacing it, may do the trick
Jun 9, 2008 at 5:20 AM
