Volvo S60 Winding Clunk When Turning
JMWIDMER
I have a Volvo S-60 2.4T AWD. When I am driving slow, when I turn, cranking the wheel, either right or left, in drive or reverse, I hear like a winding up sound coming from the rear of the vehicle then it will slow down and then a big clunk noise will happen that shakes the car. My friend looked at it today and thought that it may be in the front wheels but after looking at it while I was cranking the wheel and moving slowly he thinks it may be something more. Do you know what it may be? Please help! How much of a job might it be? Thanks, Jake
Jun 28, 2007 at 1:12 PM
BLACKOP555
  • 10,386 POSTS
while driving slowly on a flat ground with windows unrolled slowly turn through the full range, left and right, then go in reverse and repeat.
do you here a clicking noise? if so the cv joints probably need servicing.
jack up vehicle and feel for looseness in the wheel, may be bad bearings.
Jul 16, 2008 at 8:23 AM
Suggested Repair
Slowly turn the wheel fully left and right in drive and reverse with the windows down and listen for clicking, which would indicate CV joints that need service. Jack up the vehicle and check the wheels for looseness that may indicate bad wheel bearings.
Conversation Summary
The owner of a Volvo S60 2.4T AWD reports a winding-up sound from the rear followed by a clunk that shakes the car when turning slowly in drive or reverse. A friend first suspected the front wheels. The expert advises listening for clicking through the full steering range in both directions, which would point to CV joints needing service, and checking the wheels for looseness that may indicate bad bearings.
