2004 Volvo S60 Cold Start Issue
NOOM
  • 7 POSTS
ok so i took my car into volvo, who has been trying to figure out why my car has trouble starting during the first start of the day (meaning cold start after car has sat idle for appx 8 hrs or more). other than that, the car starts flawlessly for the rest of the day. volvo, over two different service visits, have given my 2004 volvo s60 2.5t 31000 miles...a computer upgrade,and fuel throttle cleaning. still the problem persists.... anything else i can do or recommend to the folks at volvo? any actual faulty parts that engage the cold start injector? please help.
thx in advance...
Oct 22, 2007 at 12:29 PM
  • 75,988 POSTS
This Volvo is it throwing out an OBD2 code/s?
Oct 22, 2007 at 12:42 PM
NOOM
  • 7 POSTS
not sure what that is, please explain.
Oct 22, 2007 at 12:44 PM
  • 75,988 POSTS
The CEL tells you there's problem within the computer's engine management systems.
Take it to autozone and get it read and comeback with the code/s.
Oct 22, 2007 at 1:26 PM
NOOM
  • 7 POSTS
as the weather gets colder i thought the problem would get worse, but the first start issue is only intermentant now since my last visit with volvo dealerr... at which time they cleaned my fuel throttles. so, total work done to date at volvo is a computer upgrade, fuel injector install (recall), and fuel throttle cleaning.
so now, i may have to start the s60 twice in the mornings 3 out of 7 days a week rather than everyday... we are headed in the right direction at least. what else could be left to check in order to have it start correctly 100% of the time?
(remember its only the first start of the day)
-noom
Nov 2, 2007 at 2:52 AM
  • 75,988 POSTS
Get the fuel pressure check, this will rule out a problem with pressure.
Nov 2, 2007 at 10:08 AM
Suggested Repair
Scan for OBD2 trouble codes and have fuel pressure checked to rule out a fuel-pressure problem on the first cold start.
Conversation Summary
A 2004 Volvo S60 2.5T has trouble on the first start after sitting about eight hours or more, then starts normally the rest of the day. Dealer work included a computer upgrade, a recall fuel-injector install, and fuel-throttle cleaning; the issue became intermittent rather than daily. The expert advised reading any check-engine codes and checking fuel pressure to rule out a pressure problem.
