1991 Volvo 940 Oil Leaks
PROINJECTION
My buddy just aquired a 1991 940 gle for 50 bucks bu it seems to have a few oil leaks, one is coming from the front of the engine under the timing cover haven't fulkly looked in to that one the other is off the back of the motor its dripping badly off the bottom of the distributer, I figured it was the rear camshaft seal until I started taking the valve cover off and found all the spark plug holes full of oil anyone ever encounter this I thought it was odd.
there is also a little oil in the coolant resevoir any help would I would be very greatfull. its a 16v 2.32L. the mileage is 160,000.
Apr 2, 2007 at 11:58 AM
MMPRINCE4000
  • 8,548 POSTS
Spark plug holes full of oil indicates bad valve cover tube seals.
Front timing cover seal would be front oil problem, and dist. O ring could be other problem.
Oil in coolant resivour is not a good sign, either a head/intake gasket.
Also check crankcase oil for coolant.
Nov 13, 2010 at 10:41 AM
Suggested Repair
Replace the valve cover tube seals for oil in the spark plug wells. Inspect the front timing cover seal and the distributor O-ring for the other leaks. Oil in the coolant reservoir may indicate a head or intake gasket; also check the crankcase oil for coolant.
Conversation Summary
The owner of a 1991 Volvo 940 GLE (16-valve 2.3L, about 160,000 miles) reports oil leaking from the front timing cover and dripping near the distributor, oil filling the spark plug wells, and some oil in the coolant reservoir. The expert says oil in the plug wells points to bad valve cover tube seals, the front leak may be the timing cover seal, and the distributor leak may be an O-ring. Oil in the coolant suggests a head or intake gasket problem, and the crankcase oil should be checked for coolant.
