1991 Volvo 940 Pulls Right
DANDERS
I have a 91 Volvo 940 Turbo Wagon, 195,000 miles...
It is tugging very hard to the right. I just got the alignment fixed this morning, but it is still tugging. The folks did say we need all 4 tires replaced (which we can't have done today $$$), but is it possible that alone will solve the problem? My father has experience working on cars, and he's already jacked it up and looked to see that the brakes aren't sticking and nothing looks broken under there.
Thanks for your help.
:roll:
Jan 12, 2007 at 3:35 AM
BRUCE HUNT
  • 3,754 POSTS
I would suggest doing a rotation of the tires and putting the back on the front. See if that makes a difference. You could have some bad chords in the tire and this should help determine if the tires or the alignment job are the issue.
Jan 12, 2007 at 3:46 AM
DANDERS
Okay, sigh of relief that you didn't come back to me with the idea that something could be broken or seriously messed up. First time owning a Volvo, and they're so expensive to get major work done to.
In case anyone is interested check out
www.fordgttv.com
a ford gt getting revamped into a racer again...by people who are much smarter than I am about cars!
Thanks for your help...
Jan 12, 2007 at 4:01 AM
Suggested Repair
Rotate the tires by moving the rear tires to the front to see whether the pull follows a tire. Bad tire cords can cause a hard pull even after alignment; if the pull changes with rotation, replace the tires.
Conversation Summary
A 1991 Volvo 940 Turbo wagon pulls hard to the right after a recent alignment. The shop recommended replacing all four tires. The owner checked underneath and found no sticking brakes or obvious broken parts. The expert advised rotating the rear tires to the front to determine whether bad tire cords, rather than the alignment, are causing the pull.
