car shuts off
1993 VOLVO 940
239,000 MILES • 4 CYL • 2WD • AUTOMATIC
SMILLER0523
when driving down the road sometimes the car stalls if you put it in nuteral it will start back up again and sometimes it can go days and not do it and then does it again any ideas what this may be? besides this it runs great
Apr 28, 2009 at 10:02 PM
ZEROKPA
I had the same problem with my 93 940 about 5 years ago - I replaced the ignition switch - the thing you put the key in - it hasn't happened since. Apparently the contacts wear out and stop contacting now and then - especially if you hit a bump and you have a lot of weight on your key chain. It's worth a shot - intermittent problems like that are a pain!
michael
May 13, 2009 at 2:59 AM
VOLVOCHICK
I bought a 93 Volvo 940, non turbo, a month ago and have yet to be able to drive it 2 days straight without something going wrong. It is stalling now...with full tank of gas...When car is warm..Just had new coolant leak fixed...the car has zero head lights as a separate issue. Service engine light is ON. From what I am reading , this intermittent stalling on this year and model is common...but, what is the cause? My mechanic is going to get rich off of me...only, I can't afford to keep fixing this car. What do you all think the issue may possibly be???
Oct 3, 2019 at 2:52 AM
  • 55,423 POSTS
It sounds like the fuel pump is going out. when it wont run turn the key off, then turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
This guide can help:
Oct 3, 2019 at 6:03 AM
VOLVOCHICK
Thank you so much for your reply! Although I was unable to figure out the cause of the stalling. I found someone who will run a diagnostic on it tomorrow.
Best regards,
Lisa
Oct 4, 2019 at 5:24 AM
  • 55,423 POSTS
Please let us know what they find. I am interested to find out.
Oct 4, 2019 at 5:25 AM
