Hi cshane,
When the engine cannot start, usually the crank sensor is faulty though you might not get the code.
Check if the wire cover of the crank sensor is bad, it usually is brittle and cracks.
The idling sensor might be a byproduct of this or it could be faulty too. Check if the wire socket is bad. Erase the code and see if it comes back.
SPONSORED LINKS
Thursday, July 17th, 2008 AT 10:41 AM
