1992 Volvo 940 surge and stall
JWALLACE314
  • 11 POSTS
Engine Performance problem
1992 Volvo 940 Front Wheel Drive Automatic 154000 miles
Volvo 940GL 4cyl, 1992.
Cranks twice then stops cranking. If I hold the key in the crank position it will pause and try to turn over again. The car has not been running smoothly. I inspected the Radio (Noise) Suppression Relay by opening the case and visually inspecting, all looks good. I resiliconed the unit and put it back in place. It started okay right after I put the relay back in, but at 2500-3000rpm the car cuts out until the rpms drop down below 2500. So as the automatic transmission moves through the gears as soon as the engine speed hits these rpm it cuts out again. Sometimes, rarely, it runs smooth even at 2500-3000 rpm. Is there a particular sensor that needs to be changed? What do you make of this problem
Apr 8, 2008 at 3:29 PM
  • 55,649 POSTS
Volvos in that year had a problem with the wiring harness, plus check the connector and look for wires that have bare spots. The insulation dilapidates and wires become exposed. Please inspect and get back to me.
Apr 9, 2008 at 3:44 AM
JWALLACE314
  • 11 POSTS
Hello Ken,
I checked the obvious wire harnesses, the ones I could visually inspect. I found a two-wire shielded harness with significant damage to the foil shield. The number on the wire is: Volvo 3547847. It is runs along the firewall and appears to attach to the top of the transmission on the drivers side. Could this affect the rpms around 2500-3000?
Apr 11, 2008 at 4:43 AM
  • 55,649 POSTS
Have you had a tune up lately?. It sounds like the ignition could be breaking down and causing the engine to missfire. please let me know
Apr 11, 2008 at 7:04 AM
JWALLACE314
  • 11 POSTS
The car had a complete tune 10 months ago, but has only been driven 50 miles since the work was done. It past its emissions test two months ago, but has not run well enough to put any mileage on. The mechanic that did the work typically works on Japanese cars. When I recently called him he thought maybe it was an exhaust restriction. Is there an rpm sensor that may have gone bad?
Apr 11, 2008 at 8:15 AM
JWALLACE314
  • 11 POSTS
This 1992 Volvo 940GL still is not running. Three weeks ago it just died on the highway and we had to have it towed home. A week later it starts again and my son drives it to the store and back with no problems. Systematically, what should we replace first to try and find the issue? Could it be a bad coil getting too hot and shorting out, then cooling and starting again? You mentioned the wiring harness can harbor issues and other forums mention sensors going awry. What’s the next step?
May 16, 2008 at 8:25 AM
2CARPRO JACK
  • 11,533 POSTS
You could throw parts at it til the end of time and still may not get it. Need to do some basic tests when it is dead, spark and fuel pressure, if both are there check for injector pulse with a noid light. If the car is running, there isnt really a problem to find unfortunatly
May 23, 2008 at 5:26 AM
JWALLACE314
  • 11 POSTS
Thanks for the reply. I went to Dave's Volvo Page - Lake Elsinore, CA 92530 www.davebarton.com and ordered the three basic parts listed below. After reading posts all over the internet, these sensors and relays seemed to be the place to start and his site confirmed.
-Crank Sensor 3547847 $43.00
-Relay 3523608 $38.00
-Noise Suppression Relay 1323592 $36.00
May 23, 2008 at 7:17 AM
2CARPRO JACK
  • 11,533 POSTS
I can see the crank sensor causing intermittent stalling, which relay is it ? Not sure if the noise supressor will cause it either, but hey he's the Volvo expert
May 23, 2008 at 9:25 AM
JWALLACE314
  • 11 POSTS
3523608 New Relay, Original Volvo (Stribel),
WHITE (LH-Jetronic Fuel Injection),
May 23, 2008 at 12:23 PM
2CARPRO JACK
  • 11,533 POSTS
The main EFI relay, that could do it as well
May 27, 2008 at 12:37 AM
JWALLACE314
  • 11 POSTS
After replacing the little white electronic fuel relay and the crank timing sensor the Volvo came back to life. We have not had a down day sense the repairs.
The starter seems intermittent and the air conditioner need work next.
Any ideas on where to start trouble shooting the air conditioning? It was 103 degree here two days ago.
Jun 11, 2008 at 11:36 PM
2CARPRO JACK
  • 11,533 POSTS
Have to be sure it is full of 134a first, system wont work if the pressures arent right.
Jun 12, 2008 at 12:57 AM
JWALLACE314
  • 11 POSTS
Okay, we had the air conditioning compressor tested and it is functional. The system is charged with coolant and holding pressure. The fan switch only works on high and the air conditioner won't turn on with the switch. The mechanic said something is wrong between the switch and the compressor, but he had no idea what.
Is there a special relay or some other piece of mechanical magic?
Jun 18, 2008 at 2:53 AM
2CARPRO JACK
  • 11,533 POSTS
My software doesnt have the wiring diagram for your car.Follow the a/c lines and see if there are any pressure switches on them, if so they should pass the power through if they are working right and the pressures are correct.Also look in the underhood power center for an a/c relay, if it has one, use a test light to see if there is power going to the relay
Jun 18, 2008 at 3:34 AM
