HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volvo
940
Engine
Symptoms
Not Running
1992 Volvo 940 Motor
RICKY D
MEMBER
1992 VOLVO 940
4 CYL
2WD
AUTOMATIC
19,000 MILES
Car will not start. No fire to the motor
Saturday, August 23rd, 2008 AT 6:23 AM
KHLOW2008
MECHANIC
Hi Ricky,
I don't understand why the car is not starting based on what you have described. Click the link and browse through whatever that might help you.
Come back if you still are not able to get any answer, but please describe the symptoms as well as you can.
https://www.2carpros.com/kpages/first_things.htm
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Saturday, August 23rd, 2008 AT 8:41 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
940 Ignition Lights
I Have A Volvo 940 1992, The Problem Is The Ignition Lights Do Not Always Come On. When I Insert The Key And Turn It Nothing But The...
Asked by
flightsimer
9 IMAGES
1992
VOLVO 940
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Volvo 940 It Cut Off
Engine Mechanical Problem 1992 Volvo 940 4 Cyl Two Wheel Drive Automatic Yesterday I Was Driving To Work And It Cut Off. I Didnt Even...
Asked by
Volvodaddy82
1 ANSWER
1992
VOLVO 940
1992 Volvo 940 I'm Freezing Up!
I Have A 92 Volvo 940 With Over 200,000 Miles. I Had To Replace The Compressor Last Year (including New O-rings And Dryer) But Now After...
Asked by
Bob Darden
1 ANSWER
1992
VOLVO 940
1993 Volvo 940 Car Lost Power And Will Not Start
I Was Driving And The Dash Lights Came On. The Car Did Not Stop Running But I Didnt Have Any Power When I Pressed The Accelerator. I Pulled...
Asked by
al22
1993
VOLVO 940
Not Start The Following Day
I Just Replaced The Battery In My 1993 940 Wagon Only To Have It Not Start The Following Day. What Could Cause This To Happen? I Had A...
Asked by
davidcal
1 IMAGE
1993
VOLVO 940
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
