1996 Volvo 850 Oil Leak After Impact
LEX480
I own a 1996 Volvo 850 Turbo station wagon. Its an automatic transmission and has around 140,000 miles. Its a 20 valve engine, I believe but I dont have the exact specs. I was driving home last night and a large dip in the street caught me off guard in the dark. I hit it at too fast of a speed and the bottom of the car hit the concrete (or at least thats what it felt like). I woke up this morning to find a considerable amount of engine oil under my car. I checked the dipstick and sure enough it was almost dry. I looked under the car with a flashlight but it was hard to pin-point the exact location of the leak. However, it looks like its leaking from under the engine. Does anyone have any idea of what may have gotten damaged? Worst and best case scenarios? ANY info would help! Thanks!
Lex.
Jun 17, 2007 at 11:36 AM
SERVICE WRITER
  • 9,123 POSTS
Worst case scenario is you ran over a guy in a wheel chair and your face will be all over the news tommorrow.
https://images.2carpros.com/forum/automotive_pictures/30961_shockedohno_2.jpg
You probably tore a hole in the oil pan. Any lights come on between the time of the collision with the unknown object (wheelchair...see above reaction) until the point of turning the engine off?
Jun 17, 2007 at 2:11 PM
Suggested Repair
Do not drive the car with the oil nearly empty. Inspect the oil pan for impact damage or a hole, and repair or replace the pan if it is punctured. Also note whether any warning lights came on after the impact.
Conversation Summary
The owner of a 1996 Volvo 850 Turbo hit a road dip and later found a large oil leak with the dipstick nearly dry. The leak appeared to come from under the engine. The expert said the oil pan was probably torn and asked whether any warning lights came on before the engine was shut off.
