1997 Volvo 850 power window
1997 VOLVO 850
LB27278
Electrical problem
1997 Volvo 850
The drivers side window will not close. It did this once before and when you pushed the window lock off and on with the engine off it went up. Now it just makes a clicking noise when you push the window button. Any suggestions? It's 27 degrees!
Dec 22, 2008 at 12:42 AM
DOCFIXIT
  • 18,828 POSTS
Most likely faulty motor need to remove door panel and see what went wrong.
Dec 22, 2008 at 12:55 AM
TEJAS81
  • 5 POSTS
[quote:d6eaeeceb6="LB27278"]Electrical problem
1997 Volvo 850
The drivers side window will not close. It did this once before and when you pushed the window lock off and on with the engine off it went up. Now it just makes a clicking noise when you push the window button. Any suggestions? It's 27 degrees![/quote:d6eaeeceb6]
My wife's car had this problem too. You can try the following too.
We had spilt coffee over the center window console, so we tried cleaning it up. Using a $10 Haynes manual, her father and I opened up the console to expose the 4 window and 2 mirror switches. Then we sprayed electrical cleaner all over it to get the grease and dirt out.
When we put it back, the window went up but it has given us problems again. However: the fact that it works intermittently (and that when it does, it works smoothly in one shot) makes us think it is a switch problem and not something with the motor.
Jan 5, 2009 at 8:30 AM
