Volvo will not crank
VOLVO 740
BRIAN42
I was driving down the road and my 740 wagon stalled out. There was a bit of a burning smell. it did not overheat according to the meter and the coolant did not overflow. Now it will not crank. Any ideas what could have cause this. The rest of the electrical system seems to be ok. Lights and radio come on just fine.
Thanks
Brian
Aug 27, 2007 at 11:52 AM
MRTANGOGUY
  • 11 POSTS
check the starter,do a starter check to see if there is 12 volts at the stater there should be 2 wires a battery wire and a ignition wire check both if ther is 12 volts the starter is bad a needsto be replaced
Dec 4, 2007 at 4:21 PM
