Voltage drop?
200,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
STEVEN GREGORY
It's actually a 2002 Bluebird tc2000 bus.
Volts at just above 12, then started dropping one day, and slowly dropped more and more. While driving one day the transmission and fuel pumps lost power, but the starter still had full power, volts read 0. Opened the battery box and jiggled the positive battery cable and the volts went to 12 and it started back up, voltage continues to drop, and I have to jiggle the positive wire to get them back up.
Sep 16, 2022 at 7:50 AM
STEVE W.
  • 15,404 POSTS
Your description sounds like the battery terminal clamp has a bad connection. You say you can wiggle it and the power returns? In that case what is moving when you wiggle the cable? The cable in the connector? The connector on the post or does the post move as well? The last one would be the worst as that would mean the battery needs to be replaced as the internal connection has failed and those cannot be repaired. The others mean that you need to clean and tighten the connectors or replace the connection if the cable is loose in it.
Sep 16, 2022 at 12:24 PM
STEVEN GREGORY
Everything feels really solid, but I could take it all apart and clean them anyways if you think that could help, nothing moves when I wiggle the cable except the cable itself, I did notice the positive cable is crimped together with heat shrink over it and tape.
Sep 16, 2022 at 12:37 PM
STEVE W.
  • 15,404 POSTS
If the cable moves at all I would start looking it over closely, what generally happens with cables is that any acid leaks at the battery will wick into the strands and corrode the metal inside, from the outside it still looks good but inside it's just the mush left behind. Remove the heat shrink and tape and see if maybe someone tried to add on a section or if it's corroded under it.
Sep 16, 2022 at 1:17 PM
