Engine not starting
150,000 MILES • 6 CYL • AUTOMATIC
DEREK BOOTAE
  • 6 POSTS
I had the motor tested no compression at all, no spark plug firing. it just turns over. Thank you
Jan 13, 2019 at 8:24 AM
  • 55,845 POSTS
It sounds like the timing belt let go. here are instructions and diagrams to help you get the job done below:
https://www.2carpros.com/diagrams/volkswagen/passat/2001
Jan 14, 2019 at 4:07 AM
DEREK BOOTAE
  • 6 POSTS
The car was tested. timing belt still together. no compression at all and no fire coming from spark plug at all. it turns over but will not start and run.
Jan 14, 2019 at 5:12 AM
DEREK BOOTAE
  • 6 POSTS
Zero compression in all the cylinders.
DEREK BOOTAE
  • 6 POSTS
Jan 14, 2019 at 5:23 AM
  • 55,845 POSTS
It could be the timing belt slipped taking the camshaft to crankshaft correlation out of wack. Can you confirm the timing belt marks are still okay?
Jan 15, 2019 at 2:17 AM
DEREK BOOTAE
  • 6 POSTS
The mechanic check it and said the timing was good.
Jan 15, 2019 at 11:05 AM
DEREK BOOTAE
  • 6 POSTS
And the valves were good.
Jan 15, 2019 at 11:08 AM
  • 55,845 POSTS
Can you take a video of the engine turning over? Also, please confirm the camshaft is turning when you crank the engine over. You may need to remove the valve cover. here is a guide to help walk you through the steps:
https://www.2carpros.com/articles/replace-valve-cover-gasket
Jan 16, 2019 at 5:56 AM
