1984 Volkswagen Van intermittent engine starting failure
NHALSAL
  • 1984 VOLKSWAGEN VAN
Engine Mechanical problem
1984 Volkswagen Van 6 cyl Automatic
This usually happens after driving for a while then turning off engine to gas up etc. I can hear a fast clicking noise. Battery is fine and new. Could it be something to do with a coil? For the starter motor?
Thanks for your time.
Thursday, November 5th, 2009 AT 12:22 PM
DR LOOT
  • 2,311 POSTS
You are having ignition problems, check your distributor makes sure everything inside of it is correctly, what is happening is the computer is overheating and shutting it down, it will do this a few times before you burn up the computer. Then you will be sorry.
Friday, November 27th, 2009 AT 9:53 AM
