Where exactly is the pump located on a 1989 VW Fox?
May 18, 2006 at 5:36 AM
The washer pump is on the bottom outside of the washer bottle. Follow the wire from the washer bottle to locate the pump.
The owner asked where the washer pump is located on a 1989 VW Fox. The expert said it is on the bottom outside of the washer bottle and can be found by following the wire from the bottle.
