2000 Volkswagen Passat Serpentine Belt
VOLKSWAGEN
STARKITTY77
what is a serpentine belt? Do i need to get it replaced if reccomended and how bad will it be if i dont? HOw much should I expect to spend on this thing?
2000 VW Passat V6
60000 miles
Jan 26, 2007 at 3:32 PM
BRUCE HUNT
  • 3,754 POSTS
A serpentine belt is the belt that generally runs all of the components under the hood that are belt driven. They can include power steering pump, water pump, alternator, A/C compressor, etc. It is a big deal. Simple item, easy to replace, very necessary as well. I would consider replacing it, especially if when looking at it you see any signs of wear, cracking, etc. Another thing that I do is take the old one and throw it on the spare tire to keep with me in case the new one should ever become defective on the road. It usually is enough to get me home. Maybe $50 for replacement and labor.
Jan 26, 2007 at 5:27 PM
Suggested Repair
Replace the serpentine belt if recommended or if it shows wear or cracking. It drives belt-driven accessories such as the power steering pump, water pump, alternator, and A/C compressor. Expect about $50 for parts and labor; the old belt can be kept as a roadside spare.
Conversation Summary
The owner of a 2000 VW Passat V6 with 60,000 miles asked what a serpentine belt is, whether a recommended replacement is necessary, the risk of delaying it, and the cost. The expert explained that the belt drives the belt-driven accessories under the hood and is important to replace, especially if cracked or worn. Replacement is described as simple, with an estimated cost of about $50 including labor.
