rough idle
VOLKSWAGEN
KEAHUPIE
I've got a 1998 VW Jetta GLX (VR6) with 5 speed and with 117k miles. I have two issues that may or may not be related:
-unusually high idle rpm: hovers around 1100-1200rpm where 700 was the norm in the past. Also, the idle rpms are not as steady and fluctuate a bit more than they used to.
-after driving on a highway for about an hour, found that the car would intermittently jerk (loose power?) for a second or two. This comes and goes in small batches and can happen at any gear. The jerking is a lot more severe than if I abrubtly let gas pedal off which makes me think that it's not engine related. If I abrubtly let gas pedal off in any gear, the car slows down relatively smoothly as it should. No stalling has occured yet (crossing my fingers).
-Here are my trouble codes:
P0103 Mass or Volume Air Flow Circuit High Input
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P1544 Throttle Actuation Potentiometer Signal too High
P1580 Throttle Actuator B1 Malfunction
P1582 Idle Adaptation at Limit
-I took the throttle off to check it and all mechanisms are in good shape even the gears and potentiometer.
-AMF sensor is responsive to throttle position changes
-throttle pos. sensor is responsive to pedal pressing (as seen in my scanner)
-Fuel filter is one year old, air filter is clean
-new spark plugs
Sep 14, 2006 at 10:45 AM
LILWE3ZY05
  • 5 POSTS
double check for vacuum leaks......they seem to be a big problem, and also check your idle air control valve.....if it is stuck open, that can cause higher idle.
Sep 14, 2006 at 1:06 PM
CAPTAINMANIACDRIVER
  • 15 POSTS
VW's computer can cause the idle fluctuation to tell you of a problem. Usually you need to then clean the airflow sensor, new sparkplugs and/or timing check. A vacume leak could cause it too. On non-CIS or Difigiant the idle stabilizer need be checked more often. It seems it's your rubber boot from the air filter to the manifold because the engine moves a bit while the air filter does not, thus opening the boot even more in first gear with most torque. When full thottle you can beat the stall. There may be a hose below into the boot which also may have come loose either end.
Oct 30, 2006 at 8:58 AM
CAPTAINMANIACDRIVER
  • 15 POSTS
I recently got over 400K miles and the ECU went out. Very difficult not. It was a weak spark causing a low rough idle. But after heating up it died until cooled. Lucky once it was going it would not stop but the idle was low and rough but raced 95%. Almost like one injector or two had a problem.
Oct 30, 2006 at 9:03 AM
