1999 Volkswagen Jetta Radiator Light
VOLKSWAGEN
AALDRICH
I hardly drive my car anymore and it has been sitting in 20 degree weather without being started for over 2 weeks. I just started it last night and it came about as close to not starting as it can go while still starting, plus the radiator light is on. What could the radiator light be signalling? As far as my car not starting, my battery is brand new and I just had something replaced that was either draining my battery or blocking the battery from working. Did it just not start good because it had been so long or could there be something wrong?
Thank you for any help! I'm new to cool climates and new to how to maintain a car I don't use.
new body style 99 Jetta 99,000 miles.
Dec 11, 2006 at 4:23 AM
CANVIS69
  • 131 POSTS
That cold weather did it, below freezing even good batteries get weak. And the sitting lowers all the fuel pressure witch is an added delay, and draw for the battery. As for the radiator light you might need to check that the anti freeze is still good and level.
Dec 14, 2006 at 4:19 PM
LOSONE
  • 1,616 POSTS
The radiator light indicates that you have low coolant. It may have failed because of the weather as they are high failure. Check your coolant level. It will not harm the vhecile to drive it if you have coolant. It does not check the quality of the coolant. that must be done with a tester.
Make sure you have the corect oil viscosity for your weather conditions. It should be started at least twice a week to keep the battery alive.
let me know losone
Dec 18, 2006 at 1:50 AM
Suggested Repair
Check the coolant level; the radiator light indicates low coolant and does not test coolant quality, which needs a tester. Use the correct oil viscosity for cold weather and start the car at least twice a week so the battery stays charged.
Conversation Summary
The owner of a 1999 Volkswagen Jetta that sat unused for over two weeks in about 20-degree weather reported a hard start and an illuminated radiator light. A new battery and a recent electrical repair had already been done. A commenter attributed the hard start to cold-weakened battery performance and lost fuel pressure from sitting, and suggested checking antifreeze level and condition. The expert said the radiator light means low coolant, noted coolant sensors fail often, and advised checking the level; driving is fine if coolant is present. Coolant quality must be checked with a tester. The expert also recommended the correct oil viscosity for the weather and starting the car at least twice a week to keep the battery alive.
