Thank you for any help! I'm new to cool climates and new to how to maintain a car I don't use.
new body style 99 Jetta 99,000 miles.
Check the coolant level; the radiator light indicates low coolant and does not test coolant quality, which needs a tester. Use the correct oil viscosity for cold weather and start the car at least twice a week so the battery stays charged.
The owner of a 1999 Volkswagen Jetta that sat unused for over two weeks in about 20-degree weather reported a hard start and an illuminated radiator light. A new battery and a recent electrical repair had already been done. A commenter attributed the hard start to cold-weakened battery performance and lost fuel pressure from sitting, and suggested checking antifreeze level and condition. The expert said the radiator light means low coolant, noted coolant sensors fail often, and advised checking the level; driving is fine if coolant is present. Coolant quality must be checked with a tester. The expert also recommended the correct oil viscosity for the weather and starting the car at least twice a week to keep the battery alive.
