1999 VW Passat V6 engine, 115,000 miles: There are two hoses that run from my Coolant Expansion tank. I know one is located at the top of the tank and runs to the radiator. The other runs from the bottom of the tank and travels to the bottom part of the engine to the passengers side of the vehicle. The coolant leak seems to be where this hose meets another assembly but I'm not sure what this assembly is.(Coolant pump?) The assembly the hose is connecting to seems to have coolant on it is well so it is hard to tell if the leak is where the hose meets the assembly (maybe a bad clamp) or if the leak is within the assembly itself. What is the assembly the hose is connected to? How can I pinpoint the leak? Will I have to drain the entire coolant system to fix this problem?
SPONSORED LINKS
Saturday, November 3rd, 2007 AT 3:14 PM
