1999 Volkswagen Golf Power Loss
VOLKSWAGEN
VISOINED
hi. i own a VW 1999 GOLF 1.9 TDI 90HP, with 150.000km.
My question is about power loss. The car works well until , reach about 100 km/h and the road goes up (more power needed), the power falls and only starting again the car it resets.
If i go down the road (few power needed) i can reach to high speed and the car doesn't fail. I have changed the Mass Air Flow sensor but still the same.
Please help me.
Regards and keep the good work.
Victor Coutinho (PORTUGAL)
Aug 3, 2007 at 11:14 AM
  • 75,988 POSTS
[quote:e9543498bc="visoined"]hi. i own a VW 1999 GOLF 1.9 TDI 90HP, with 150.000km.
Please help me.
Victor Coutinho (PORTUGAL)[/quote:e9543498bc]
Disconnect the exhaust flange that meets with the exhaust manifold-hang it to the side go for the test drive. Is it still there.if not inspect the exhaust system C/Converter.
No power going up hills,but plenty in straight run. If not it, we'll take it somewhere else.
Thanks for dropping by.
Aug 4, 2007 at 5:37 PM
Suggested Repair
Disconnect the exhaust flange at the exhaust manifold, hang it aside, and test drive. If the power loss is gone, inspect the exhaust system and catalytic converter for restriction.
Conversation Summary
The owner of a 1999 Volkswagen Golf 1.9 TDI reports power loss around 100 km/h under load, such as uphill, that returns only after a restart. Low-load driving is fine, and replacing the mass airflow sensor did not help. The expert suggests a test drive with the exhaust flange disconnected and, if the symptom disappears, inspecting the exhaust system and catalytic converter.
