1983 Volkswagen Scirocco Cylinder Pressure
VOLKSWAGEN
CLOSIN
long story short...looking into buying a Volkswagon Scirocco '83 MKII one problem...low pressure in one of the cylanders..all i need is a simple answer: what will i need to fix it if i buy and and most importantly: HOW MUCH WILL IT COST???? and how much time will it take?
Aug 13, 2007 at 8:07 PM
  • 75,988 POSTS
[quote:fce3715ea1="closin"]long story short...looking into buying a Volkswagon Scirocco '83 MKII one problem...low pressure in one of the cylanders..all i need is a simple answer: what will i need to fix it if i buy and and most importantly: HOW MUCH WILL IT COST???? and how much time will it take?[/quote:fce3715ea1]
It depends where its leaking pressure at if its below the cylinder head it can get real expensive
If its low they should be able to tell you where its leaking. By doing a compression or leakdown test. This will decide what's needed and how long its gonna take. Parts/Labor
Aug 13, 2007 at 8:20 PM
Suggested Repair
Have a compression or leakdown test done to find where the cylinder is losing pressure. The leak location determines the needed parts, labor, cost, and time; a leak below the cylinder head can be expensive.
Conversation Summary
A buyer considering a 1983 Volkswagen Scirocco MKII asked what it would take, cost, and how long to fix low pressure in one cylinder. The expert said the answer depends on where the pressure is leaking and recommended a compression or leakdown test before estimating parts, labor, and time. A leak below the cylinder head can be expensive.
