I took my car into the mechanic today because the check engine light was continuously flashing and loud sound was coming from the engine. The mechanic told me that the engine had lost compression. He said it could be one of 2 things: the release valve in the oil pump not functioning properly, or the hydraulic tensioner/chain (?) could be broken. He checked the timing belt and the timing belt was okay. Want to know if this seems right...I read some of the other posts and lost compression seems to be related to the cylinders not the oil pump. Thanks for your help!
1999 Volkswagen Passat Lost Compression
I took my car into the mechanic today because the check engine light was continuously flashing and loud sound was coming from the engine. The mechanic told me that the engine had lost compression. He said it could be one of 2 things: the release valve in the oil pump not functioning properly, or the hydraulic tensioner/chain (?) could be broken. He checked the timing belt and the timing belt was okay. Want to know if this seems right...I read some of the other posts and lost compression seems to be related to the cylinders not the oil pump. Thanks for your help![/quote:a68d1ac1c3]
.I read some of the other posts and lost compression seems to be related to the cylinders not the oil pump. Thanks for your help![/quote]
Loss of compression could be caused by Timing belt/chain,blown gasket/bad valves/worn rings/cylinders/piston
For the noise could be the oil pump went south and the engine is not being lubricated-could also cause problems with engine bearings.
Suggested Repair
Have compression loss checked for a timing belt or chain problem, blown head gasket, bad valves, or worn rings, cylinders, or pistons. Investigate the engine noise as a possible failed oil pump causing poor lubrication and bearing damage.
Conversation Summary
The owner of a 1999 Volkswagen Passat reported a flashing check engine light, loud engine noise, and a mechanic's diagnosis of lost compression, possibly from an oil-pump relief valve or a broken hydraulic tensioner or chain. The timing belt had already been checked and found okay. The expert said compression loss can come from the timing belt or chain, a blown gasket, bad valves, or worn rings, cylinders, or pistons, and that the noise could indicate a failed oil pump starving the engine of lubrication and damaging bearings.
