Lost compression 1999 Passat
1999 VOLKSWAGEN
HEC_ROD
Hello-
I took my car into the mechanic today because the check engine light was continuously flashing and loud sound was coming from the engine. The mechanic told me that the engine had lost compression. He said it could be one of 2 things: the release valve in the oil pump not functioning properly, or the hydraulic tensioner/chain (?) could be broken. He checked the timing belt and the timing belt was okay. Want to know if this seems right...I read some of the other posts and lost compression seems to be related to the cylinders not the oil pump. Thanks for your help!
Aug 14, 2007 at 2:57 PM
  • 75,988 POSTS
[quote:a68d1ac1c3="Hec_Rod"]Hello-
I took my car into the mechanic today because the check engine light was continuously flashing and loud sound was coming from the engine. The mechanic told me that the engine had lost compression. He said it could be one of 2 things: the release valve in the oil pump not functioning properly, or the hydraulic tensioner/chain (?) could be broken. He checked the timing belt and the timing belt was okay. Want to know if this seems right...I read some of the other posts and lost compression seems to be related to the cylinders not the oil pump. Thanks for your help![/quote:a68d1ac1c3]
.I read some of the other posts and lost compression seems to be related to the cylinders not the oil pump. Thanks for your help![/quote]
Loss of compression could be caused by Timing belt/chain,blown gasket/bad valves/worn rings/cylinders/piston
For the noise could be the oil pump went south and the engine is not being lubricated-could also cause problems with engine bearings.
Aug 14, 2007 at 3:42 PM
