how to replace a heater core in 87 quantum
1987 VOLKSWAGEN
BUGG_S_BUNNY
i just need to figure out where the heater core is so that i can replace it. if anyone has any idea then please let me know
Feb 22, 2006 at 9:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello.
Replacement procedures are below for your vehicle's heater core..
REMOVAL:
Disconnect the negative battery cable.
Drain the cooling system.
Remove the two heater inlet hoses at the firewall.
NOTE:
On some 1977 and later models, it is possible to remove the heater core without removing the heater case. To determine if this is possible on your vehicle, remove the center console side panels (if equipped). Locate the heater core cover positioned on the side of the case. Remove the screws or unclip the cover, then remove the cover for access. If there is sufficient clearance to pull the core out without damaging the heater tubes, remove the core from the case and you may skip the rest of the removal procedure.
Remove the heater case. Locate the heater core cover located on the side of the case. Remove the screws or unclip the cover, then remove it.
The heater core can now be slid out from the case. If the retaining clips break off, don't worry, they can be replaced with screws.
INSTALLATION:
Insert the heater core into the case. Install the heater core cover, making sure that the gasket on the cover is properly fitted.
If applicable, install the heater case.
Connect the heater hoses at the firewall. Make sure the seal fits tightly without any gaps. Fill the cooling system to the proper level.
Thanks for using 2CarPros.com!
Mar 3, 2009 at 7:44 PM
