can you please outline the procedure for heater core replacement in a 2001 jetta with a/c? thanks!!
Nov 6, 2007 at 4:50 PM
BLACKOP555
✓ASE Certified Mechanic
pretty much drain the coolant system and disconnect the hoses from the fire wall. next take off and mark all the wires on the dash and steering column. once that is done the next step is to take out hte heater core and install in reverse order.
Nov 6, 2007 at 7:03 PM
