2006 Volkswagen Jetta Front Tire Lean
VOLKSWAGEN
CRISTINANEW
2006 VW Jetta GLI 10000 miles.4 cynlinder.
I recently hit a curb pretty good and busted 2 tires and cracked two rims......After replacing the tires and rims, my front passenger tire is now crooked. The top of the tire leans into the car. I am unable to take the car into the shop for a couple of weeks and am wondering if it is ok to drive short distances...slowly. If I go over 45mph it pulls real bad and is making horrible noises when I hit speed bumps............Any ideas???
Thnx.
Jan 23, 2007 at 7:27 AM
CARUNDELL
  • 602 POSTS
[quote:bbbd0a24a0="cristinanew"]2006 VW Jetta GLI 10000 miles.4 cynlinder.
Thnx.[/quote:bbbd0a24a0]
Hey christina
Sounds like ya definitely tweeked something in the front end. I would not recommend driving the vehicle more than 5-10 miles per day as that tire will wear out very, very quickly if you do and avoid highway speeds for the same reason!!
Chris
p.s. I also recommend a 4 wheel alignment when you get the repairs done!
Jan 23, 2007 at 11:10 PM
CRISTINANEW
[quote:dfb525fe58="carundell"][quote:dfb525fe58="cristinanew"]2006 VW Jetta GLI 10000 miles.4 cynlinder.
Thnx.[/quote:dfb525fe58]
Hey christina
Chris
p.s. I also recommend a 4 wheel alignment when you get the repairs done![/quote:dfb525fe58]
Thanks a lot for your input!!
Cristina
Jan 24, 2007 at 7:12 AM
CARUNDELL
  • 602 POSTS
You're very welcome!
Chris
Jan 24, 2007 at 7:15 AM
Suggested Repair
Limit driving to about 5-10 miles per day and avoid highway speeds until the damaged front end is inspected and repaired, then have a four-wheel alignment performed. The inward-leaning tire indicates suspension or alignment damage from the curb impact.
Conversation Summary
The owner of a 2006 Volkswagen Jetta hit a curb, damaging two tires and rims. After replacement, the front passenger tire leans inward at the top, the car pulls above 45 mph, and it makes noise over speed bumps. The expert advised limiting driving to 5-10 miles per day, avoiding highway speeds to prevent rapid tire wear, and getting a four-wheel alignment after repairs.
