1999 Volkswagen Beetle P1128 Lean Code
VOLKSWAGEN
SWAMPMAN
Trying to get some info for computer code P1128. I have a 1999 Volkswagen Beetle, 63000 miles,2.0 4 cyl. eng. The car runs great. The light will reset for a couple days then return. My diagnostic tool reads factory code P1128 fuel air metering,has anyone delt with this code? Thank-you
Jan 17, 2007 at 9:23 AM
CARUNDELL
  • 602 POSTS
[quote:dffb5e82e8="swampman"]Trying to get some info for computer code P1128. I have a 1999 Volkswagen Beetle, 63000 miles,2.0 4 cyl. eng. The car runs great. The light will reset for a couple days then return. My diagnostic tool reads factory code P1128 fuel air metering,has anyone delt with this code? Thank-you[/quote:dffb5e82e8]
Hey swampman
P1128 refers to a "lean fuel trim condition" sounds like there may be a vacuum leak or secondary AIR system fault. Both can cause a lean condition over time. I would go right to checking for vacuum leaks first! Let us know!!
Chris
Jan 17, 2007 at 11:11 AM
SHANEWATSONLEGALASST
Many of factors can come into play. You may have a bad gas cap on your vehicle and it may be affecting the system through the evaporative emmissions.... This appears to be a common problem on these type of systems.
Jun 3, 2008 at 11:36 AM
Suggested Repair
Check for vacuum leaks first. A secondary AIR system fault can also cause the P1128 lean fuel-trim condition.
Conversation Summary
A 1999 Volkswagen Beetle 2.0 with 63,000 miles sets P1128 fuel-air metering, described as a lean fuel-trim condition. The car runs well and the light returns a few days after reset. The expert advised checking vacuum leaks first and noted a possible secondary AIR system fault. Another comment suggested a gas cap or evaporative-emissions issue as a possible factor.
