2000 Volkswagen Jetta Check Engine Codes Fix
VOLKSWAGEN
DDCYR40
  • 41 POSTS
Hi, I've got a 2000 VW Jetta 2.0L and the check engine light has been on for a year or so, and i just got them checked at an oil change and here is the list:
Po134 - 02 Sensor Ckt - no activity (bank 1 sensor 1)
P1128 - manufacturer controlled fuel and air metering
Po442 - Evap emission control system leak (small)
Po300 - Random/multiple cylinder misfire detected
Po301 - Cylinder 1 misfire detected
Po171 - System too lean (bank 1)
Po304 - Cylinder 4 misfire detected
Po302 - Cylinder 2 misfire detected
it has been getting poor gas milage and sometimes stutters at a stop light in drive. i've ordered an o2 sensor for before the catalytic converter. looks like most of this could have been caused by a faulty one. any idea if i am diagnosing it wrong. it is going in tomorrow to get the o2 sensor changed, so if you can reply asap, it would be great. Thanks a lot.
Feb 19, 2007 at 3:30 AM
CHEVY22
  • 1,375 POSTS
check engine light on for a year is noooo good , i would start by replacing the 02 you have a code for and the misfires may go away but maybe not , the vw's have coil issues also , but start with what you know is bad the 02 sensor and maybe a maint tune up since its been running like that so long
Feb 19, 2007 at 3:51 AM
DDCYR40
  • 41 POSTS
what would you suggest for a tune-up? Plugs? I don't really know what else, air filter just was changed along with oil. It hasn't had the timing belt changed, or that I know of, (I've owned since 65,000 miles and it is at 89,000 now). Any idea on the labor of a timing belt? anything you can give me here is much beneficial. thanks
Feb 19, 2007 at 5:38 AM
CHEVY22
  • 1,375 POSTS
the 02 for starters , then plus and wires , you might want to check the manual on the t belt i think its at 90k and im not sure on the labor , but def what i listed first ,in that order ,and then reset the pcm and drive it for a while and see hwat happens , atleast you can do those repairs on your own and same chunks of cheese
Feb 19, 2007 at 1:35 PM
DDCYR40
  • 41 POSTS
i replaced the o2 sensor, and has been running for over 2 weeks with no codes and good gas mileage. i guess that solved the problem. thanks
Mar 5, 2007 at 2:38 AM
CHEVY22
  • 1,375 POSTS
good job
Mar 5, 2007 at 6:12 AM
Suggested Repair
Replace the upstream oxygen sensor first, then reset the PCM and road-test. If misfires remain, inspect spark plugs and wires and check the timing-belt service interval near 90,000 miles. In this case, the oxygen sensor replacement cleared the codes and restored mileage.
Conversation Summary
A 2000 Volkswagen Jetta 2.0L had a long-standing check engine light with oxygen-sensor, lean, EVAP leak, and multiple misfire codes, plus poor mileage and occasional stuttering. The expert advised starting with the faulty upstream oxygen sensor, then plugs and wires if needed, and checking the timing belt near 90,000 miles. After the oxygen sensor was replaced, the car ran more than two weeks with no codes and improved mileage.
