An unhappy cold mkii golf engine
VOLKSWAGEN
WIELDABEAST
I've got a 1.3 mkii golf 1991 (carb), done about 130k. Every morning i go start it fine (as long as i put my foot on the gas whilst i do it) but it doesn't idle! It stalls almost every time i take my foot off the gas, the revs just drop! when i see it dropping i can save it by giving it some revs but its a nightmare every time i stop! After about 10 mins when the engines warmed up its fine but until then i have to sit with my foot slightly on the gas to stop it stalling! Also when i pull away in first my revs dip quite significantly before going up again. Not sure if they're related.
Suggestions much appreciated!
Nov 20, 2007 at 6:32 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
hows your spark plugs look also change hte fuel filter also i think you may have a inline fuel filter in the carbuerator. it may needs to be adjusted for a richer mixture.
is the choke operating properly?
Nov 20, 2007 at 10:00 PM
