1993 Volkswagen Jetta White Smoke
1993 VOLKSWAGEN
JODYDAVIDS
I have a 1993 Jetta that has white smoke coming out of it when it is up to temp in idle. It will not pass an emmisions test also. I am not losing coolant. I have replaced the ECU,coolant temp censor, oxygen sensor,cat, and muffler. Is it possible that there is water in the exhaust. I bought it from a wreaker. There didnt seem to be any white smoke before I put on the new exhaust parts. Is there anything that could be causing this. Is it just steam or something more serious?
Jan 30, 2006 at 9:28 AM
2CARPRO JACK
  • 11,533 POSTS
if the previous engine failed then the cat is full of coolant. Take it out on the highway and stand on it for a little while and see if the smoke goes away
Feb 10, 2006 at 8:40 AM
Suggested Repair
If the previous engine failed, residual coolant may be trapped in the catalytic converter. Drive the car on the highway under load for a while and check whether the white smoke clears.
Conversation Summary
The owner of a 1993 Jetta reports white smoke at idle once the engine is warm, plus an emissions-test failure, but no coolant loss. The ECU, coolant temperature sensor, oxygen sensor, catalytic converter, and muffler have already been replaced. The car was bought from a wrecker, and the smoke was not noticed before the new exhaust parts were installed. The expert said a failed previous engine could have left the catalytic converter full of coolant and recommended a sustained highway drive under load to see if the smoke goes away.
