2006 Volkswagen Jetta
MAPLESS5016
  • 2006 VOLKSWAGEN JETTA
  • V8
  • 4WD
  • 111,000 MILES
Whenever I stop then accelerate it jerks what does that mean?
Sunday, June 6th, 2010 AT 9:13 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, June 6th, 2010 AT 8:44 PM
